Idle oil pressure...hks oil filter works!..?
11K views 23 replies 12 participants last post by  sim evo 5
#1 · (Edited)
My oil pressure at hot idle when my engine was built was 1.2-1.4 bar:)...yep perfect.:):coolsm:
Was like that for a few months untill i did my 3rd oil change (same oil used everytime...pro r 15w50) and fitted a hks pink:blush::lol: oil filter which claims to improve oil pressure...?>.?...does have a mad swirly design inside...
http://www.sumopower.com/product/hks-hybrid-sports-oil-filter--52009-ak001
http://www.ebay.co.uk/itm/HKS-HYBRI...5-6-SUMO-/280936652670?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4169211f7e
Straight after that my hot idle pressure is at 1.7-1.9 bar..even 2 bar.
Ive even fitted a brand new oil pressure sensor today and still 1.8 bar hot idle.
Im guessing the filter actually works:confused:...surely a good thing..?
Anyone else used these with any results??
#16 ·
Hmm...loads of figures around:confused:
quote= rated at 99.99997% efficiency on particles 0.01 micron and 0.12 micron MPPS.
quote= HKS Super Hybrid Filter -... that uses a micronic mesh screen to filter particulates as small as 40 microns.
quote= The HKS hybrid sports oil filters also feature better filtration, filtering the engine oil at 20 microns, whereas most OEM-quality oil filters are at 25
#18 ·
Hi guy's I just finish installing my K&N oil filter with the R-Spec sandwich adaptor plate. My Evo 4 for has a Evo 8 engine, so when i hooked up the oil pressure & temp the readings were as follow (hot Idle 900-1000 rpm):
Oil Pressure 1.1-1.2 bar at idle & 5.5-6.0 bar at around 4500 - 5000 rpm.
Oil temp is around 60 celcius & never seems to go above 90 celcius, is this normal?
