21 - 40 of 46 Posts
Does anyone know if :D below
I have a controller/link display that at the mo is reading mph , oil temp and oil pressure , ive just plugged in a boost sensor but nothing :confused: is it that the sensor only works a gauge and the display dont show it :confused:
Any ideas Ad :)
FQDan - see my post above re the map sensor positioning - it needs to be vertical mate :)
Adam,
check all connections as a first, Have you any warning flashes on the gauge? this would indicate a faulty sensor or connection - check them aswell, are the gauges all the same ? you cant mix link and bf gauges on the same controller and the link display wont read one or the other signal.
will keep watching for your answer and try to help as best i can mate
Ewan
Adam,
connect all sensors to controller including link display - what do you get? - i sthe boost not working? - if so - sensor is fooked
the controller can take up to 7 sensor readings incl output to a link display - if your oil temp/press and fine then check map sensor wiring and plug including the sensor itself - if there is an issue with the sensor the controller should emit a constant beep - sounds like the controller may have a fault on that input or the sensor is knacked so much that the controls cant see any connection there at all
strange one Adz, However di da bit of checking as not used this kit for a while - found the following:-
Defi-Link Display is a multipurpose monitor which provides information on speed, oil temperature, water temperature, oil pressure, fuel pressure, and exhaust temperature by connecting to the Defi-Link Control Unit II or the Defi-Link Control Unit(end of sale).
Defi-Link Display can be connected to Defi-Link Meters and Defi-Link Meter BFs by using the DAISY CHAIN wiring system.
The display uses OLED(organic light emitting diode).
OLED is an advanced display which is self light emissive, high contrast, high response, low power consumptive, and large view angle. It uses optimal technology for instant readability without afterimages of flicker even when seen from the passenger's seat.
Real-time digital information includes speed, oil temperature, water temperature, oil pressure, fuel pressure and exhaust temperature. Sensor sets need to be purchased separately to display the information on pressures and temperatures.
Vehicle performance data and peak values are placed in memory for 3 minutes, allowing examination of data after running the vehicle.
*Defi-Link Control Unit II has a 3 minute memory. Defi-Link Control Unit has a 40 second memory.
When the RPM signal wire is connected to Defi-Link Control Unit II or Defi-Link Control Unit, 2 warning levels can be set in addition to the warning setting made by Control Unit II or Control Unit, enabling the setting of a total of 3 warning levels(Tachometer Triple Warning Mode).
When the water temperature sensor is connected, the warm-up condition can be monitored.
A graphic animation plays after the ignition is turned on or off(Opening Mode/Ending Mode).
An easily recognizable graphic on each setting screen helps guide easy setting of warnings for Defi-Link Meters and Step Graph(Setting Assistance function).
The Warning LED lights when the set warning value is exceeded for oil temperature, water temperature, exhaust temperature and engine RPM. The Warning LED lights when measured value drops below the set warning value for oil pressure and fuel pressure.
Trouble locations are shown by graphics so that connection problems can be quickly corrected(Self-Diagnosis function).
The structure of the mounting base allows height and angle adjustment so that it can match the shape of the instrument panel.
The Defi-Link Indicator(sold separately) can be connected to the display.
Defi-Link Control Unit II or Defi-Link Control Unit(end of sale) is necessary to operate Defi-Link Display.
Defi-Link Display is applicable only for 12V vehicles.
To display pressures and temperatures, sensor sets needs to be purchased separately. Defi-Link Display displays only speed without installing sensors.
Mentions nothing about Boost sensing - so I guess you need the gauge aswell mate.....I am popping into Singapore in a few weeks - I can pick one up cheap if you like?
Ewan
Thanks for that mate :)
Seems a bit crap , did have a guage but thought get this be better :rolleyes::D
Got the blitz boost contr. as a guage , but just thought get it to display on the link display as well :blah:
Would have thought it would do it , fork knows why not :confused:
Ad
On the display you can set boost warning pressures.
It does not dispaly boost though. Everything but.
no probs Adz - I seem to recall looking at a link meter some time back and dismissing it cos it didnt do this - trick peice of kit if it did all seven gauge inputs - Sorry I couldnt make it work by magic for ya mate!!!
Ewan
In my case I just had boost and water temp gauges, but this can apply to whatever wires you need to feed into the engine bay. There is a grommet slightly up from the accelerator pedal (see picture 1) which leads to behind the suspension area (see picture 2). It's very fiddly to get to from the engine bay, so I removed the grommet and fed a coat hanger through the engine bay. In the engine bay I then taped the wires to the coat hanger and pulled it back through to the footwell. I then fed these wires underneath the drivers side carpet, and up to the controller unit.
i did this but i reverse. i.e pushed the coat hander through from the inside into the bay, then taped the plugs that connect to the control unit to it and pulled back through into the footwell.
most fiddly part of this was geting the damn grommet back in properly :wallbang:
MOONDUST FRST, the sensor is supposed to be mounted vertically...
tip of the day for people who have the black ones (like me)...
if you want to see the guages in the day time and dont wish to drive with your sidelights on then wire both the orange and white wires from the control unit to a ignition 12v source!
crap pic as my phone has no flash but you get the idea...
if the gauges are wired correctly then they light up with ignition on, not with the lights. they should dim when you switch lights on.
really? well summats up with mine then rich as they dont light up with the ignition. my gauges only light up with the white illumination wire connected to a power source. i removed the white illumination wire from the harness altogether tonight and tested how the gauges worked and they worked the same as they did without the lights on pos 1. i must admit i did find it strange that they didnt light up like that as non volvo owners dont drive with their lights on all the time!
21 - 40 of 46 Posts
