1 - 11 of 11 Posts
Anyone able to shed light on this?
Checked the bore size and they are spot on (85mm), can still see the cross hatching.
Now coming to install the rings, from the Wiseco guide I got the numbers like this
85mm to Inches - 3.3464
Took that number and x it by the recommened details (Street Moderate Turbo/Nitrous).
So (TOP)3.3464 x .0050" and (2ND)3.3464 x .0055"
Giving me
TOP = .0167 (17 rounded up)
2ND = .0184
Now checking the rings in the bore give me strange numbers (Bear in mind the bore was checked right through for size).
TOP was spot(0.17) on but 2ND came in at .023 :eek::cry:
What would you guys recommened? Leave as is/It'll be ok? Get different rings? Open it up some more?
Should mention this is on a VII Block
Ive just had this problem on my stoker build 2.3 thou is far to tight for a ring gap :eek: I " filed mine to fit " using a carb stone and ring file:smthumbup
Billy
All the other rings (TOP and OIL) fit perfect...exactly as stated on the sheet supplied by Wiseco...
The 2nd ring is MILES out, the gap is already too big without even touching it. Wiseco say .018 according to their thing but without touching it, it's at .023
the second ring has a bigger gap so dont worry.although the end gaps you have seem a bit low.e7 piston ring end gaps are
ring 1. 0.2-0.3 limit is 0.8
ring 2. 0.3-0.5 limit is 0.8
thats in mm
thats in mm
Confused now, how can my end gaps seem low when the above is alot smaller
If I'm wrong, someone correct me but 0.2/0.3 is about .011 thou ? I have .018, meaning I'm off by .007 thou?
Arggg! :mhihi:
sorry mate i havent converted it the specs i gave u are standard e7 end gaps wasnt till afetr i read the post again that i saw you meant thou ooops
Dont use the OEM ring gap specs for the Wiseco rings use the calculation/formula provided with the piston set :smthumbup
If they calculation works out to 18 thou gap the ring to suit if, its to wide contact your supplier and find out if the correct rings have been matched to your piston set (the ring numbers on the top of the ring next to the gap )
Billy
I didn't notice anything in the box, just the paperwork with the rings! I'll double check tonight (Rings came with the pistons)
Ok! I've found out from Wiseco that I have the new improved ring set with a larger gap by stock on the 2nd rings! Although I still need to find out the tolerances or recommened sizes (Found the info out on their website).
1 - 11 of 11 Posts
