1 - 9 of 9 Posts
Hi all,
I have an evo 6 and have done stage 1 mods regulated by an apexi power fc. My mech suggested a garrett turbo with the following specs:
Compressor housing AR .70, comp wheel 56.6 mm trim 57 and turbine housing 0.63 with wheel 54mm and trim 69 (don`t know if I got that one right). He claims it can make 350-400 atw. I`m not sure as I think it will lag too much with the high ar. Anybody got any opinions on whether the lag will be too much? Ideally I would like to run 1.3-1.5 bar and start spooling at between 3200-3500 rpm (earlier would be better) with full boost by 4500 rpm while exceeding 300 whp.
Any opinions would be welcome. Thanks guys.
Hi all,
Yes it will lag too much.
Ok thanks for the info. I can customise the ar, trim and housing for both the turbine and compressor as my mech is an authorised garrett dealer so what would you suggest for a fast spooling turbo which would be good for 350-400 atw? Btw, the turbo I am looking at is a t04e garrett. Would a .63 a/r housing and 50 trim do the trick? The GT series of turbo is too expensive where I`m at.
Cheers guys.
Cheers guys.
Go for the FP red turbo :smthumbup
1 - 9 of 9 Posts
