1 - 2 of 2 Posts
Could someone tell me if E7 front shocks fit the E5? I presume that the 6's are the same but i'm not sure about the 7.
Mine are on their way out, & i have seen a set from a 7 with low miles, but not sure if they will fit.
on the front.....
clamps/mounts on the lower portion of the front dampers are bigger/wider on the e7 than e5
You'll have to use a a 'sandwich plate' in between the damper mounts/clamp and the mounting point on the front hubs to get them to fit properly.
- also need use top-mounts or camber plates specific to your e5
if these are coilovers which are normally an inch shorter than oem shox.....should be ok
- ride will probably be harsher as e7 is heavier than
if they're not coil-overs.....wouldn't bother especially as you're probably not going to be able to trial-fit before buying
...look for e4 to e6-specific stuff
1 - 2 of 2 Posts
