Re:Who sells Pagid RS4-2 ?
I would rather get the RS14s, they squeal less and have a slightly higher temperature rating. I guess one of the motorsport parts suppliers on the links page will have them. Same rear, make sure you keep the anti squeal shims that are glued to the OEM pads!
People also recommend Ferodo DS 2500 and 3000, appearently they eat less disc or as Andre (advevo) says, they leave the disc nice and shiny :D
DO NOT get EBC or something!!
Try the following
http://www.ecparts.co.uk/home.htm
Froggie uses his car on mountain rally stages and gets serious heat into his brakes. The RS4-2's are really good and if the survive on Blade's track car and work really well on my road car, I don't think you can go far wrong.
Re:Who sells Pagid RS4-2 ? and what pads for rears
Cheers Claudius and Simon, will get onto it right away.
Funny you should say about removing the anti squeal plate off the OEM pads, but the Mintex 1155 I've just killed didn't hardly ever squeal and all I did was put copper grease on the back plate! Plus I bedded them in good and proper at Donington last year. I'll have to dig out the old pads and remove the shim immediatley.
Thanks again
Steve
