Guest
·Ok, as you all know, I have 330mm AP disks with 6 pot calipers and 4 pot AP rears on standard discs, with Pagid RS-42s all round.
Braking is phenomenal. Now the following is my opinion, but I would like other people's feedback:-
The 362mm weigh significantly more. The calipers are the same, so the brake force does not change. The disc is bigger, so will not get quite so hot. As heat isn't an issue, with the brake ducts, the benefits seem low compared to the increase in unsprung weight. Admittedly, a harsher pad would get the discs hotter, pushing the balance in favour of the 362mm discs - but then the discs would wear quicker. Therefore, there is no benefit in me going for the 362mm kit given that I have the 330 already.
Fitting 362mm discs with bigger calipers would make a difference, say the 8 pot AP watercooled calipers. This means even more unsprung weight, which isn't good, but the braking should be better. Ultimately it is down to the pads, and harsher ones will be required. This may not give as good a modulation as the current setup. Would also introduce an imbalance as the rear would be underbraked relative to the front. A bias adjuster would solve that, but that would mean repiping the brakes to get rid of the diagonal split, and new master cylinders too. That may mean losing the servo.
In the end, I am not sure the extra braking would be that not noticable, given the lighter weight of my car - i.e. on tarmac, I would start to exceed grip levels if I braked any harder than I already do, even with slicks.
So am I right in thinkin there is no point, and I should well alone?
I don't have a brake problem, just itching to get my chequebook out again
