Had a search around and couldn`t find anything.
I want to install and Ingalls Stiffy engine damper but the extra thickness on the mounting strap which fits under the strut brace drivers side means I have no thread left to screw the studs back down. It has D2 coilovers fitted and the std studs are also to short :confused:
Anyone ?
wheels studs will work - same dia and pitch iirc
Unfortunately not, wheels studs are larger diameter, I had the same prob and looked at the wheel stud route :blah:
how did you sort it ??
cheers for the response guys. someone somewhere must do a replacement stud thats a tad longer.
All sorted now thanks ... got a bolt and nut to do the job instead of a stud as the correct length and size proved to be to difficult.
