I`m presuming i simply disconnect the two pipes to the boost actuator (under the black cylinder, behind the airbox) and attach them to the Dawes?
Rich.
hi rich
no it takes a little bit more than that http://www.lancerregister.com/graphics/tongue1.gif border|EQU| 0 align|EQU| absmiddle >
the big outlet part that does not have a bleed (the straight pipe) goes into the turbo outlet. and the one with the bleed with (90 degree) goes into your wastegate
sam
O.K., i`m happy with that.....doing that will completely do away with the pipe that goes upto to the afore mentioned boost actuator under the black cylinder, is this correct?
Rich.
yep
all you need is two pipes in a lube kind of thing with the dawe in the middle. the pipe from and to the 2 port solenoid are not used at all.
just leave it connected though
sam
