1 - 3 of 3 Posts
I am lowering my evo this weekend as well as fitting a de-cat pipe. What I need to know is what is the standard tracking setting for the evo 4 as well as if someone know what is the tracking setting once is lowered 30mm ?? another question is the air probe senser for the cat! if I de-cat the car and not put the air probe senser in what difference will it make compared to I put it in the de-cat pipe as well???? hope some one can help me before the weekend. thanx
Leon.
There are other people better qualified on here to give you advise on suspension set up (or try a search) but the standard set up tolerance for the E4 is:
Front
Toe in: -3mm to |PLS|3mm
Camber: -1°00' ±30'
Rear
Toe in: 3mm ±2mm
Camber: -1°00' ±30'
The 'probe' to the CAT on the E4 is in fact just a high temperature sensor and all it does is throw up a warning light on the dash should the CAT overheat. I think you can remove it completely (check though before you do) or you can always tape it securely out of the way, it makes no difference to the performance of the car.
1 - 3 of 3 Posts
