Try just part the way, and then more if you need to, TBH (to be honestviper4460 said:thanks mate your really help full shall i just adjust it all the way in yer? thanks again(bt the way whats IIRC Mean)
Ralliart ECU won't fix it, i tried this for the same reason, you need a mappable ecu, with a map sensor, but the HKS stabilizer thing does work apparently, I think Makes on here tried one with good results, but as always, i could be wrongviper4460 said:well thats my 6 i have a 7 now im buying a ralliart ecu tommorow so i will bung that on dunno if it will make any difference but its just a hks pro summit well it was almost wound all the way in so now i have wound it in all the way see if it works will the ecu sort it?
No idea, any HKS stockist/tuner i would assume, and no idea how much, sozviper4460 said:well where can ya get a hks stabaliser thing from do u know and how much are they. if its gonna cost a lot ill jst take it off and use the standard dump valve![]()
