Guest
·Any takers on this one:
Not the normal tappet noise - just to get that out of the way http://www.ltregister.f9.co.uk/graphics/happy1.gif border|EQU| 0 align|EQU| absmiddle >
When the engine is cold at idle, sounds normal.
If I raise the revs normally the engine sounds normal.
However, if I blip the throttle quickly - generating positive boost on the boost gauge then it makes a very strange, slightly high pitched rattle. Its only a light sounds, not a deep grumbling you would get with a crank or similar.
I've had my head under the bonnet and bliped the throttle using the cable directly to try and trace the noise. It appears to be coming from the turbo or turbo area. IE definalty loudest with me ear-hole near the turbo (warm !)
If I allow the engine to warm thourghly (I.E. not just the water temp but long enough for the oil temp to get up as well) then it doesn't make this noise.
Oil has just been changed to a good quality semi-synthetic of the right grade (This is an Evo 1 by the way). It had started to make this noise prior to the oil change. Oil has been changed every 3k previously.
There is no smoke, power seems normal, no oil consumption to speak off.
So... what does anyone reackon ? Turbo bearing, or something worse. Or hopefully someone will say they had the same noise and it was a loose pipe (please [img]http://www.ltregister.f9.co.uk/graphics/happy1.gif border|EQU| 0 align|EQU| absmiddle > ) I suspect turbo as it only comes on as the boost gauge starts to generate positive boost - i.e. when the turbo is starting to be stressed. If I bring it up slooowly then there is no noise - that I can hear anyway.
Help appreciated fellas....
TonyC
TonyC
