1 - 2 of 2 Posts
Hi guys..
I just wonder..
Whats the best or wh must I have..
If I want an turbo upgrade, I want 450hp.. Most turbo upgrades do have an external wastegate.
Why?? If you look at an Cosworth, then you see hp figures up to 550hp with internal wastegates..
Can I use an new manifold, T4 turbo with internal wastegate??
Thanx.
Evolooser
Hello
The cosworth turbos are standard with inturnal wastegate and is easy to find the right 550hp turbo you just use the RS500 t4 so it fits on the manifold of a 2wd car no problems with plumming and only costs around 1,200, on the evo you have to change the manifold to fit any turbo then you have problems with mounting a actuator so it is easyer for fit a exturnal wastegate also it works slightly better.
Thanks Mark
1 - 2 of 2 Posts
