1 - 3 of 3 Posts
do you think i can use Castrol LSX for the AYC too?! anyone knows who's the manufacturer of MMC Active Yaw Control (AYC) oil ie. Castrol, Penzoil, Redline?!
difference between AYC and LSD oil?!
As you have logically suggested since the AYC oil is for the clutch packs then I would have thought a LSD oil would also do.
I would only suggest you use LSD oil as a last resort if you definitely cannot get hold of AYC oil.
Whatever u do, do not try and substitute the AYC oil.
The AYC fluid appears to be a combination of ATF and diff oil, but only they have the recipe.
We need to get it analysed by gas chromatography or some sh!t like that.
U must try and get the original item from Coordsport.
The Original stuff works, I have covered over 59,000 miles in my E6 gsr and its only £11-12 a bottle ( 1 litre)
and u only need 0.7 l for the AYC fluid change.
1 - 3 of 3 Posts
