hi guys just wondered what i would need to buy to get a fq300 e8 to around 400bhp?
the spec i have in mind is the following, i want a reliable car as its a daily driver.
hks 272 cams
walbro fuel pump
sard fuel pressure reg
pistons
rods
arp bolts and studs
hks adj pulleys
770cc injectors ( maybe )
maybe change the valve springs
1.2mm hks head gasket
air filter
tubular manifold and evo green turbo
dump valve ( bov)
autronic sm4 ecu
avcr boost controller
and suspension and brake change.
think ive over done it abit but want the base of the engine to be done incase i decide to up the power and will save me stripping the block down again and just need bolt ons to do it.
You're looking at 450 - 470 bhp more like mate with that spec.
As said already, there's a lot of money there, 400 is far far cheaper to achieve.
Dave
MLR Oldie
Ball park figures off the top of my head
hks 272 cams £400
walbro fuel pump £80
sard fuel pressure reg £100
pistons + rods £750
arp bolts and studs £150
hks adj pulleys £200
770cc injectors ( maybe ) £250
maybe change the valve springs £200
1.2mm hks head gasket £100
air filter £100
tubular manifold and evo green turbo £2000
dump valve ( bov) £150
autronic sm4 ecu £1000
avcr boost controller £400 (£600 if Ants price is right)
and suspension and brake change. £1000 - £4000 depending on what you go for
Thats £7080 - £10080.
The above figures may be well out but they are just guestimates.
You may also want to factor in,
Clutch £1200
3mm Lash adjusters £150
Intercooler and hardpipes £1000
thanks for getting back to me guys I thought I might of over done the spec abit but it's gonna be a good base and be reliable, I won't need to over do it on the boost and thinking of using 85.5mm piston depending on the bores.
