1 - 3 of 3 Posts
My friend is buying a 1996 Lancer GSR, ( CM5A ), and is wondering if there is standard evo suspension, ie, shocks and springs, that will fit directly in the car? The car is an import from Japan.
Will Evo 5/6 suspension fit in with no probs?
Cheers in advance
Alan
Nope, completly different.
It actually has more in common with the evo1,2,3's.
Evo1,2,3 rear suspension will fit fine as it has the same lower mounting type.
As for the front, it uses the same strut setup which has the sway bar connected to the strut (can't remember which evo used this), but it also uses evo4,5,6 type top mounts (uses 3 bolt top mounts instead of the 2 bolt type).
Hope that helped.
1 - 3 of 3 Posts
