Guest
·On my tuning spree with my EVO, one untouched area is the gearbox, diffs and transfer box. Mine is an RSX, so no AYC to worry about. I am not sure if I have the front LSD or not, or whether this is a good idea anyway.
My main puzzle is ratios. On a track, speeds over 130 are rare, but do happen. Goodwood and Thruxton can result in 140|PLS|. I find the GSR gearing on certain slow corners can leave the car stuck where 2nd is too high, and 3rd is too low (under the boost). Changing to second also wastes time.
The RS gearing (lower 3rd/4th/5th and final drive) worries me as I might loose too much top end, and might spend all my time changing gear! As my car will rev to 8500rpm at least, and should be carrying over 400bhp, the RS gearing may be a liability.
One member suggested using the final drive only, although the 3rd/4th/5th gears only would probably work for me also. My calculations would seem to still leave a reasonable top speed (over 140 to 150 with my engine).
I happy with the shift quality, particularly with the B and amp;M quick shift, and many a proper race driver has said the gearchange is one of the best they have tried. But I can't help but be drawn by the thought of a Dog Box! Problem is, I have never lived with one, or tried one.
How different is it? I know I can do clutchless upshifts with a dog box, but is it really that much better? Not worried about the noise or anything, but how long do they last? I have heard a few thousand miles before each rebuild!
Also, what about the transfer box? For track work, 50/50 split is a pain. 65/35 that the CUSCO unit offers sounds better - can I just swap this, or do the front/rear diffs need to be replaced also. Cusco do these too, so what are the advantages?
Any help, greatly appreciated - I think this is one area that would be too expensive to experiment with!
