1 - 5 of 5 Posts
I am soooo confused with the massive choice of brake pads...
Please can anyone recommend rear brake pads and part number for Evo VIII GSR (2004) 276bhp?
Theres too much choice both Brembo and other makes and or opinions!
Would be so grateful of advice and ideally a web link need to keep the price down a bit though, so need a happy compromise. Found some on ebay but looks a bit dodge as they say if out of stock they will send alternative.
Currently the cheap LPR Brakes pads from CAF are making a HORRIBLE noise even with copper slip :mad:
Mostly town and motorway driving.
Running Brembo front pads and rear was Brembo, before changing to these awful cheap screeching LPR rubbish.
I'm not able to drive it currently as way too loud and stopping quickly from high speed is not great!
Will check out ferodo ds2500 and just seen some forum reviews for Orangestuff...
Just go with some standard brembo or good quailty standard replacements they will be up to the job, dont fit uprated rears without doing front also or you will unbalance the car.
Do you have the anti-squeal shims fitted on current pads as rear is prone to squeal if not fitted ?....or fitted backwards which is quite common, another possible cause is worn/lipped rear discs and pads are catching on raised area which causes noise.
Ian
1 - 5 of 5 Posts
