Discussion Starter #1
As above, what power can standard evo gearboxes handle??
what else should I know about them if im thinking of buying one?? does much go wrong with them?? are they reliable when tuned?
cheers :D
I think we have a couple of people pushing 400+lbft through them without any major problems, although they run uprated clutches I'm pretty sure the rest of the box is basically standard.
People have run standard boxes with 700+ (with shot peened bits) but not massively reliable (particularly if you launch hard). Generally, around about 550-600 is the time you really need to think of dog gears to get long term reliability.
Edit - this applies to later cars rather than the early ones which I'm not sure about
Just noted the other part of your question - depends on who tunes it but yes they can be (more so than the Cossie at similar power levels ISTR) Take a look at the buyers guide for more info (home page)
Discussion Starter #4
thanks for the info :D
dont mind having to uprate the clutch and flywheel but was hoping the standard box would cope with circa 500 as uprated boxes are expensive :crackup:
ive been putting 500 or so through mine for over a yr with no problems.
However i did have to build a new shotpeened transfer box after i destroyed 3 in that time. Thats just over 4000 miles BTW
