hi oil man bit stuck on which oil to use in my evo 6, 28000 miles exhuast and airfilter only, slighty noisey tappets when warm, currently useing 5w-30 fully synthetic vauxhall performance oil (same as put in the astra coupe turbos) should i stick with this or use another grade?? many thanks.
Tarmac Tyre Shredder
Oilman recomended silkolene pro s 10w 50 to me..top oil.
supposed to be really good for noisey lash adjusters.
put uprated ones in off evo400/rg motorsport, with silkolene.
quiet as a mouse..........shhhhhhhhhh.
put uprated ones in mate if you can afford it and never worry again bout tappets again
P.s more than likely the noise will return if you just change the oil,cleaned mine out properly,but were ok only for 4 months :(
thanx mate will go for that oil then, if it gets them a bit quieter for now il be happy. :)
