1 - 5 of 5 Posts
What is the correct viscosity of engine oil to use for an EVO VI (in case it needs topping up)?
Anil.
There are a few trains of thought on this onw. Generally Ralliart recommend Castrol RS 10/60 but I found that using 5/40 fully synthetic made the engine a lot quieter (tappet sound disappeared). Regular oil changes are recommended if you drive the car hard and often. I try to change every 1500 miles.
Yep. Can't argue with that. I use fully synthetic 5/40W and change it frequently.
I use the same now. This is the oil recommended by the Mitsi dealer I use for servicing.
15/50 MOBIL 1 MOTORSPORT IS WHAT MY MITSI DEALER RECOMMENDED,BUT NOT THE NORMAL THIN STUFF.
1 - 5 of 5 Posts
