Hi guys, ive got a water leak on my evo 6 and it seems to be coming from the bottom of the rad via some sort of nozzle, ive took my pics if this helps
The small plastic wing nut in the picture is a drain plug for the radiator, you should undo it then it should come out of the small nozel, see if you can tighten up the wing nut with your hand if not try undoing it so that the water starts comming out the radiator and then tighten it back up again and see if that helps.
Ime not quite sure but there may be an O ring on the wingnut and it may of corroded, if the first thing i suggested dont work try taking the wingnut out completely and see if you can see if anythings worn or broken.
