1 - 3 of 3 Posts
Hi folks.
My front washers are only dribbling water when I pull the stalk, but the back washer is working fine. The motor is whirring as expected, and I've removed the pipe from under the bonnet (driver's side) and tested ... again, just a dribble. I want to remove the pump in the boot to check the filters, but I'm struggling to find any "how to" guide, and what to look for/test. Any help would be appreciated.
Id remove the washer bottle in the boot and give it a good clean out.
Then remove the pumps and do the same, then refit and check the pipes,
Fill with new fluid (screen additive) I added hot water,
Disconnect the pipe from scuttle to bonnet jets. Then pump through.
Hopefully should improve.
To remove the bottle is easy. Just remove the 2, 10mm bolts and wiggle upwards
Then disconnect pipes and wiring, you will have to remove the interior side carpet
Ant
Thanks mate! Sorry I didn't reply sooner, but I never received an alert that the thread had been replied to. I'll give this a try later today.
1 - 3 of 3 Posts
