Cheers dudeJen evo
http://indigo-gt.com/mitsubishi-evo-x-fuel-pump-relay/
If it doesn't work just type in fuel pump relay in search bar on Indigo GT site.
Davie
I believe so!Is the Orange one made by Panasonic the latest relay now???
http://www.rosssport.com/Brands/Mitsubishi-OEM-Parts/Evo-X-Fuel-Pump-Relay-MIT8627A049
For the price of it, It would be beneficial just to replace it. They seem to be taking out a revised one every year. I assume because they aren't up to the job either. I've changed mine twice so far. I may change it again this year. Maybe a touch of paranoia but would rather pay £12 for that over £5k+ for an engine.Hi, as an evo x FQ400 owner and a newbie I am reading this forum with great interest, I have just checked my fuses and my fuel pump relay is no. MR588567. This I take it is the original and could be a problem waiting to happen,so far it has been ok and having removed it it looks good and does not make a noise when I shake it, that said would I be best ordering a replacement from indigo-GT ,I see on there website they have a relay no.MR122409 (£12.00) is this the right one, I don't know what colour it is.
My car has only covered 7,500 miles from new which might explain why the relay is still ok.
I am enjoying being a member and love reading all the forums,there is some great information out there . Cheers all.
Hello everyone,,,Hi,
I know alot of people are aware of the issue of faulty Evo X Fuel pump relay's but the last 3 cars I have had on the dyno all have had a faulty original one fitted.
The cars come in and they are generally driving fine but when we a power run there is nowhere near enough fuel going in.
The AFR should be under approx. 12 youporn.wiki/ xhamster.vip/ redtube.onl/ AFR when on full throttle, but with a faulty relay they barely get under 14 AFR which causes massive temperatures in the engine.
The relays are cheap enough and they can be changed in less than a minute, they are available from your local dealer.
I know this sounds like scaremongering but there is no way you will see the issue without either having a fueling check or an engine failure.
The part number is MR122409
And here is a picture of where it is located
