I fitted a Forge VTA dump valve a few weeks ago for the novelty factor mainly, and although I didn't get any idle problems, I did feel that it was hesitating slightly when changing gear, and could be a little rough occasionally, on part throttle.
Anyway, a few days ago I decided to put the stock recirc valve back on to see how it compared, and I found an oily, gunky (technical terms... look them up) residue in the blanking plug that slots into the pipe just before the turbo. Shining a torch into that pipe also reveals a light film of the stuff there whithin.
I have no idea where it's come from, and I was hoping someone here might know? I'm pretty sure it's as a direct result of the BOV, but the only place it could have come from is through the turbo the wrong way!?? There's nothing in the filter element (standard induction), or the bottom of the air box or anything like that. I know it wasn't being produced while the factory recirc valve was on, because it was clean and dry when I took it off, and it's clean and dry a few days after running around with it back on.
Any ideas?
Any ideas?
