1 - 3 of 3 Posts
what suspension components can i swap over from a later model evolution. arms, sub frame.. i tried searching and it only showed IV V VI compatibility..
Anyone know? I'm stateside so it's hard to come across any older model evos, I have access to evo 8/9 parts... Thanks again to anyone that can chime in
You can use all the rear arms from a Evo VII/VIII/IX in a Evo V/VI. You can also use them in the Evo IV, but I recommend to change the front arms to Evo VI parts, as they are all in alluminium and the IV almost everything is iron.
But with this you will need to change transmissions, as the Evo IV ones are shorter.
You might need to change the wheel setup, as the car will be wider:D
1 - 3 of 3 Posts
