1 - 5 of 5 Posts
Hi guys,
I have this gearbox in front of me, and the shaft with the red arrow below is quite loose (lateral movement). Is it normal?
Secondly, is it the famous "output shaft" which can be replaced with an uprated version (Brena for example)?
I did some research and its a bit confusing.
Don't do that, you'll break it...
You need to take the gearbox apart, take the gear off the centre diff and split the diff.
The output shaft slides out but is retained by a circlip that needs to be transferred to the new shaft.
1 - 5 of 5 Posts
