1 - 2 of 2 Posts
Discussion Starter #1
Hi,
Next weekend I am having GAZ Coilovers, Tein Adjustable front top mounts and Cusco rears and was wondering would having the geometry set up to standard III settings be okay?
Evo 2/3
Front Toe In: 0mm
Front Camber: -0° 50’
Front Castor: 3° 55’
King Pin: 12° 55’
Rear Toe In: 3mm
Rear Camber: -0° 55’
Or can anyone recommend a nice balanced setup for mainly road use with the occasional track day!?
Cheers! :)
Bjorn
if you want better turn in.....the front needs to be set at 2-3mm as well
+ bit more negative camber
1 - 2 of 2 Posts
