Guest
·ooops i have just spun the car
nothing happened ie no damage but that was very close
this morning i checked the tyre pressure and it was all over the place, looked at the manual and it said 2.2kg/cm2 front and 1.9kg/cm2 rear i think that equates to 28 rear and 32 front. went out on my favorite roads again and this time there was a lot less sliding, the car seem to do every thing it was asked to do effortlessy. these are some of the twistist wet country roads you will find by the way
until a right hander which i thought i will try to get the back end out a little bit and the back end just snaped on me so quick !! i ended up doing 180 degrees. the way the grip gave was not progressive in the slightest, every thing happened so bloody quick. usually if the back end starts sliding i apply the throttle a little bit with an opposite lock and that usually does the trick, but not this time.
so what do you guys think ? is tyre pressure that needing adjusting or is just the standard tyres that are crap as has been mentioned before by a lot of people? or do i just need to change my driving style? or is this the dreaded AYC that over cooked things.
it is just the car seem to be playing Jackel and Hide on me
