Guest
·I am thinking of upgrading to 18in wheels and I just need some info (I will probably forget it when I hear the exact prices but I already have a rough idea).
The wheels I am thinking of are 18inx8 and I need to know the following:
The C/bore is I assume 67.1mm on the E6?
I also assume the offset won't need to be changed? (ET38)
What tyre size do you recommend, the obvious is 235/40 but that makes an overal 11mm diameter difference whereas 225/40 only makes a 3mm difference. Will 225/40 be suitable on a 18inx8 wheel? Will an 11mm overall tyre diameter increase make a noticeable difference if I use 235/40?
Will 18inx8 wheels with these tyres cause any clearance problems (standard suspension, maybe lowered later)?
Sorry for so many questions, especially as I may not go ahead with it but any help would be appeciated
(and theres me thinking all those people who bought larger wheels were possers
