Discussion Starter #1
just fitted my EGT and was seeing 765 deg C max.
this seems very low - i would have expected 850 at least. what sort of figures has anyone else seen?
this is at 1.05 bar boost ambient temp 13 deg.
EGT's
Oli,
I typically see 875 degrees C at the end of a 2 Bar boost run circa 7000 rpm.
My probe is mounted in the collector upstream of the turbo (No 4 cyl, closest to the flywheel usually runs hottest).
Simon
Discussion Starter #4
the probe is in the same place as skn's i.e in no4 runner before the turbo.
i can't see the point of putting it after the turbo as you are assuming a temperature drop across the turbo.
thanks for the info anyway.
looks like my 765 is about right for 1 bar ish.
i will try to keep it below 900 when start setting up my power fc.
on a different topic whats the lag like on the gt30 hybrid simon?
Lag
On the road, I get 1.8 bar in 4th gear by 4000rpm, and full boost (2.1 Bar) by 4200rpm.
Obviously doesn't spool as fast as a std twin scroll, but it does give more from 4k up.
Good luck with setting up your FC. Incidentally, as I am now happy with my map, I have removed my egt probe as a safety precaution ;) . If I do any more mapping, it will be refitted.
Discussion Starter #6 (Edited)
hmmm, yes i've already lost the tip off my probe in the couple of weeks between installing it and connecting the electronics. must have tightened the nipple too much - although was being careful.
anyway turbo still boosts ok so it must have gone straight through!
weird though as i had the same sort of probe in my monte turbo which saw 1000 deg regularly and lasted 3 years.
thanks for the info on the turbo - i guess i will go with a slightly larger than OE twin scroll ball bearing unit when mine fails.
