1 - 5 of 5 Posts
Just fitted a Turbosmart \dual Port BOV to my VII. ('kin awesome too!)
It clearly states in the instructions that it should be 10mm from radiator fan cowling, and also 10mm from the exhaust heat shield.
Problem being, it touches both!
It is wound out most the way (soft). When wound in it clears the heat shield but not the cowling. I don't see the cowling being a problem, but am slightly concerned about heat transmitted through the heat shield affecting the rubber seal inside the BOV.
I cant see how to re-position it without cutting the boost hoses.
Any ideas?
1 - 5 of 5 Posts
