Throttle response is quite good. Right now with my current setup, starting from a low RPM in say 4th or 5th, I will have--you guys like bar for boost, right?-- about .7 bar by 3000 RPM, and 1.4|PLS| bar by 3600-3700 RPM -- this is a standard bearing turbo, NOT ceramic ball bearing. Rolling on the throttle from 4K|PLS| and full boost is achieved almost instantly. I almost wish I chose a larger turbine housing as this turbo spools up almost TOO quick. I run a maximum of 1.65 - 1.7 bar when racing-- for normal around town cruising, boost stays around 1.3 bar as the normal pump gas we get is absolute ####, and there normally isn't a 'need' for more boost than that
I am currently running a garrett T3/T04E turbo (T3 hot side, T4 compressor side). If anyone is interested in the trims, I would be happy to divulge them.
Bottom end is still completely stock, with 123K miles (~200K km's I think that is). Only internal mods to the motor are I've removed the balance shafts, am running a set of HKS 272 intake and exhaust camshafts, and have a set of crower titanium valvespring retainers.
So you mean to say us yanks are winning the 4G63 hp war? I for sure would think there would be some real sick EVO's out there... My car is definitely one of the quickest street driven 4G63's in the area, but there are a good deal MUCH faster than myself that are still street cars. For reference, the cars best 1/4 mile ET is 11.63, and highest mph so far is 119 mph.
rich
