As title, i'm after a turbo outlet pipe (J pipe in yank terms :) ) must be from an fq turbo (i've been told they're slightly larger???)
Ben
Re: size
DREWBY said:
how much wider are they about 13 mm, can you slap a tape across them for me, cheers. D :) ;)
Sorry, cannot do as the pipe was installed some time ago, however the smaller pipe is approx 1.5" and the FQ pipe outlet is approx 2.25" - although you need to use a 2.5" hose connector as the lip in the FQ j-pipe is quite pronounced.
