1 - 3 of 3 Posts
Noticed a slight leak from this area and assume its a paper gasket that should be replaced, anyone know where i can get one from other then mitsu?
Also is it just a case of simply undoing the two 10mm bolts and repalcing the gasket? will there be enough movement with the bolts out to clean both surfaces and fit a new gasket?
Any advice would be much appreciated,
GUM
p.s i am doing an oil change at the same time.
Dave at Ears sells them, not sure if that one comes separate I got one in a gasket set.
Yeah no need to remove the pipe can be done in place.
thanks for the reply mate, will try camskill and dave at ears on monday.
1 - 3 of 3 Posts
