1 - 5 of 5 Posts
Only after a display at the moment, suspect this might change but for now just need guidance on what gauge and how to fit at the cheapest price available.
Simon
there are loads knocking about on E-bay mate, apexi.. defi etc like jonny said.... at the end of the day though a boost gauge is a boost gauge mate you can get a cheap one that looks ok for 30notes man...
as for fitting, it;s a doddle mate will take you all of 10-15 mins mate :D
simon5 said:
Which one is the best, where to buy from and how easy/technical is the fitting?
Please give your thoughts as I am looking to install ASAP.
Simon
Fitting is straight forward, it will take you ~hour to do it properly and route the vacuum hose through the inner arch, main cable grommet and into the cabin, then hook up the power feed (take from cig lighter) for illumination.
Connection wise T into the vacuum line to the blow off valve and not the fuel regulator.
1 - 5 of 5 Posts
