Guest
·Last week, 5 laps on the Ring. Noticed a bit of an oily smell. Did not see anything.
Yesterday, in lap 4, suddenly oil over the right side of the windshield. The oil stick had come up and ca. .75 liter of oil had splashed out. Very messy. The dip stick was very loose though.
My engine breather works fine (the one from the engine cover) through a catch tank (into the intake again).
After cleaning, I noticed oil coming out from the silicon hoses near the bov: the whole intake side was full of engine oil! The catch tank only had a few mm's of oil in it. Oil appeared to be cleaner in the catch tank as well. Compared to inside the hoses going to the bov from direction intercooler.
What is going on? Are the two oil spills related?
Engine runs fine, water temp ok. Boost ok. Have no oil pressure gauge.
Is there a second breather dumping into the intake side???
I dont think it is the o ring of the compressor. Probably, knowing my luck, it is something to do with combustion gasses passing into the oil pan and raising pressures there. Compression test? Better pistons/rings?
Running ca. 1.4 bar and car is 13000 km 'old'.
I am starting to believe that the Evo with a bit more boost is not tough enough for Ring use.
