Guest
·Terrible noise coming from my 25000 mile E6 gsr
I can only descibe this noise as what you might get if you had 2 metal discs spinning in opposite directions and amp; pushed them together. The noise level is relevant to how fast the car is moving and amp; does not alter wether the clutch is in or out. All oil levels have been checked and amp; are ok. Been told its more than likely a gearbox bearing. This is a road car only. Has anyone else had a similar problem? Or any sensible advice would be greatly appreciated. TA
