just wondered what i can do to reduce rolling resistance (asside from tyres)
i know 9's arent the lightest thing ever but mines a pig to push and it cant be helping performance or economy.
i have ado8's at 32psi which are probably the biggest factor, im using motul 75/90 in the gearbox and ayc recently bled.
recently rebuilt the rear brakes as the handbrake sticks a bit after being left overnight but made no real difference as you have to 'crack them loose' when you first pull away then theyre fine (discs only warm after a long drive)
bearings or brake pad type likely to have any effect?
