1 - 8 of 8 Posts
As above, I'll be trying to set up base idle settings after fitting a new (used) ICV using the MUT 3, I've gotten lucky and a friend is borrowing one from his mate in a mitsi garage for the night. I'd like to have as much info as possible before we start. Does anyone know what the voltage readings should be for the TPS with the ignition on and throttle fully closed please?
I've found all other relevant info (i think :lol:) regarding supply voltage and resistance readings for the TPS and ICV. Any further advice would be appreciated.
I'd like to try to do this for myself before biting the bullet and paying someone, so cheers in advance for the help................. :smthumbup
Mick.
Discussion Starter · #6 · (Edited)
Thanks for all of the advice guys, i'll give it a lash tonight..............
Ps, is it possible only to park the stepper motor with the MUT or something like evoscan?
Or can it be done in any other manner?
1 - 8 of 8 Posts
