1 - 20 of 25 Posts
I was wondering if anyone could recommend a dump valve for my Evo 2?
I been told that installing one could decrease the power and cause lag when going through the gears...any advice would be appriciated
:confused:
So if I was to put one on that didnt recirculate would I get any running problems?.....its only because I like the psssst sound that I was going to put one on but if its going to cause problems or lack of power then I will probably leave it
hi have the blitz super sound on mine sounds great. and i have never had any idling problems etc.
as for losing power i maybe wrong but dont think you lose any..
i got a bailys one on mine.. never had any issues..
yeah it does take a tiny bit longer for the turbo to spool up as its got to replace the air.. but it does sound good lol..
no running issues.. tho i may change back to the standard soon
I want to put a recirculating one on my IV. I am assuming it has the other type because it gives the pssss noise when i come of the fast pedal. What will be a good one to use and can i fit it myself. I am not over keen on the delay you get from the non recirculating type and want to go back to factory if you like.
i have blitz one on my evo 4 and got no prob with mine
yeh u do get a bit of lag and loose abit of power but its cheaper than buying a turbo or reconing it every 45000 miles because the standard valve only dumps half of what a aftermarket valve will.
Thats a bold statment. Do you have any facts to back this up? Given that most after market DVs that use the stock IC pipe will have the same diamiter hole for the DV to draw the excess presure through, the stock DV would have to be a horribly ineficent design for an aftermaket DV to show a 100% increase in vented gas. How do you explain all the Evos that have a lot more than 45000 m iles on them that don't have an after market DV. Where are the power graphs that show cars loosing power?
MB
Can anybody recommend the best recirculating dunp valve ?. I think the quicker turbo pick up will siut my driving style better and i wont have the car for 45000 miles so not over worried about any issues with turbo wear etc.
Carl
1 - 20 of 25 Posts
