1 - 5 of 5 Posts
2000 Evo Tommi Makinen Edition
Hi
I've just opened up my front transfer box, to find a open diff unit.
The car is a tme, is has a tme gearbox and history of being changed.
But nothing said about the transfer case.
What am I needing to measure to determine if it's a tme transfer case?, I've heard cwp is different and also the bearings are also different to a gsr and that an lsd (quaife atb I plan to run) will not fit in the tme case.
Hoping that someone has just put a open diff in the tme case.
Any info much appreciated
Here's some pics
Motor vehicle Automotive tire Gas Engineering Machine
Automotive tire Motor vehicle Gas Auto part Automotive wheel system
Automotive tire Engineering Gas Rim Auto part
Automotive tire Gas Rim Automotive wheel system Composite material
Sent from my E6653 using Tapatalk
Mitsubishi made a number of different types of transfer case for the 4/5/6, with different size internals as well as the TME one. That case design with the two holes on the cover looks like an early 4/5/6 case.
The only TME cases I've seen have this style of cover:
but I'm not sure that all cases of this style will be TME ones.
I suspect the OP's original transfer box failed and was replaced by one from a 4.
The easy way to tell a TME box is that the LSD diff pack will have cap head hex bolts as opposed to countersunk ones.
Cheers,
Simon
I confirm the case on my tme is as Simon's (and mine is a 100% Evo 6 tme). Never had transfer box change or anything. It has these 2 threaded "ears" at the bottom which were really too close to my exhaust:
Of course what's inside could be different but I assure you this is the transfer box originally fitted on my Evo 6 tme.
1 - 5 of 5 Posts
