1 - 10 of 10 Posts
I am trying to find a GReddy turbo timer harness to fit my Evo 3. The only ones i can find are:
Eclipse 1989-1994 & Eclipse 1995-1997
anyone any ideas?? :confused:
the DSM harness won't work in your car...
the ECU/wiring is totally different
....you may have to hard-wire it in
btw
don't forget that the timer can only be used when you are there,
if on a public road
as it's illegal to leave a car running whilst unattended
....obviously you/the car would have to be seen by the cops to get done for it...
Wreckleford said:
You sure? I heard that they use the same TT harness...
the ECU codes are different
unless I mis-read.....
perhaps there's some way of linking the wiring then?
Buy a turbo timer harness from HKS or Blitz for an Evo 3. Either of those will work perfectly well with your timer. All manufacturers share the same 3 pin plug between the timer and the harness. I have a Razo harness on my Blitz timer and it works perfectly.
1 - 10 of 10 Posts
