Most local sticker places should be able to do small stickers, but it'll depend on the size if it's cut stickers or small printed ones.
Lee at fcm (I think) was on here that could do stickers.
Reactions: Arronevo8
Get some "unique ones" made up.
Note: "all decals stickers must be aligned to perfection"
The amount of times I have seen decals/stickers on all kinda things and not levelled up correctly drives me crazy, with Evos it give me sleepless nights - OCD is one MF'er :crackup:
S.Wales R.O./Electrician
I make them all the time in work for switches of all sorts.
We used to print on sticky back paper and sellotape over the top which worked quite well but our new printer will print onto sticky back plastic which gives a much better look.
Either that or something like a Dynamo label printer, they don't cost much.
Another option is to have the switch mounting plate made from something like Traffolyte. The can cut the holes and also engrave the names which you require. I wouldn't use 3mm as anything thinner will flex too much. Cost wise somewhere between £20 and £60 depending on size.
Regional Organiser
Aah traffolite tallies, as used by the RN all over the place:smthumbup
