1 - 2 of 2 Posts
When I've got the sanny down sometimes the car feels as if it's stuttering. It feels as if it's being starved of fuel or it has too much fuel. Sometimes my car also backfires.
I have a III and it's initial history is slightly unclear as for some reason it made 315 on the rolling road with an hks exhaust and decat. The boost gauge indicates that the car boosts up to 1bar.
Any ideas lads?
check plugs...put in some ngk BR8ES with smaller gaps
check leads
check coil packs
check boost and vacuum pipes
has it got an adjustable fuel regulator
....if so should be running approx 41 psi ...perhaps a little less
also check air-fuel ratio on wide-band lambda
1 - 2 of 2 Posts
