1 - 14 of 14 Posts
i have an evo 4 with a iv engine and tt turbo a greddy profec boost controller evo 8 injecters and asfar as i know it has been mapped for the turbo. i was running it at 1.0bar but when its on full boost it seens to stutter (full boost only 1.0bar) and am not sure what is causing it any ideas guys?????
Could be loads of things, the 'as far as I know it's been mapped' is not good. What ECU does the car have fitted, as you can only remap the V onwards ECU. If it still has the IV ECU fitted, the VIII injectors should not be used.
i just got the car not long ago and i have recept for a map but i dont know what was tweaked it has a tme ecu and an upraterd actuator
Be worth giving the previous owner or the place that mapped it a call, see what boost it was mapped up to.
regapped the plugs and still the same, found out the car was mapped at 1.5bar any other ideas lads
1 - 14 of 14 Posts
