1 - 9 of 9 Posts
Hi Guy's
Just got En EVO 4 GSR, With EVO8 clutch and fly wheel, RS gear box, Now I think I have a problem with the AYC, Takes about 3 miles with no noise then you start getting a loud Howling, whining noise when cornering, even on the streight you can rock the stearing wheel back and forth and you can get it to make loud strange whining, not grinding or knocking. Been to the "The Garage" in Hamilton apparent "specialist" recons he has never heard a noise like it. Had the AYC bled and toped up, still the noise persists.
Any help would be very welcome as only got 2 weeks left on warranty and the garage "Ellete Cars" are trying to fob me off, they cant find anything wrong, recon the noise is normal for an old car, I know this is not the case. I have drove a few evos and never heard noises when cornering.
Richard
I know the bearing noises and it aint that, could be the CV joint, you think a specialist would be able to pin point that streight away so not sure its that. Still confused :-(
Sounds like a possible AYC problem. If you need another specialist try Extreme in Whitburn - not too far away and they know about Evos!
Hope you get it sorted.
AYC pump
:confused:Does anyone know what noise a knackered AYC pump would make, I think it may be this making the squwaking noises?
1 - 9 of 9 Posts
