1 - 2 of 2 Posts
North Scotland R.O
Whats the easiest way to straighten the steering wheel on my VII?
im gonna take out the 12mm bolt near the spined knuckle connector near where the steering arm goes thru the bulkhead and see if there is enough movement to do it that way
cheers
steven
try getting your tracking done, i had mine done at the weekend, using laser alinement. The steering wheel is held inplace with a clamp, the front wheels on discs, car started, and the tracking adjusted using the gauges. In some extreme cases, you may hit lucky and be able to remove the steering wheel and slot it back on the next tooth which may be dead centre or close to it.
1 - 2 of 2 Posts
