1 - 5 of 5 Posts
· Registered
Anyone know what they are off the top of thier head for a 5/6?
Including the number of rows would be superb!
Whilst we are on the subject, does anyone know what the biggest cooler you can fit in without having to hack the front of the car to pieces is?
· Registered
I have a 25 row Mocal 235mm oil cooler and its BIG compared with the standard one :) No body mods needed but I have removed the water bottle that sits behind to allow better thruput of air (otherwise the cooler sits right in front of the bottle which blocks the passage of air)
cheers
Darryl
· Registered
Ah - thanks!
The Mocal 235mm was the one I was looking at - can you fit anything bigger than a 25 row one in? (not even sure if i would need to yet though).
How is it fitted? have you in effect tipped it on its side so the inlet & outlet are on a side rather than the top?
Cheers!
· Registered
Oh & can i be a pain & pick your brains on how its fitted?
The options are: Female, 5/8BSP Male, 3/4BSP Male, 1"BSP Male, 1/2BSP Male, 10JIC Male, 12JIC Male, 16JIC Male, -6JIC Male & -8JIC Male
I presume they are all relevant to the type of connectors for the hoses, but I have no idea what I need! Lol
· Registered
Hi Chris - this is the >>>old thread <<< on the subject posted by Gerrit (NRing) who I copied. It shows some good pics of his installation.
On mine the new hoses were fitted to the old banjo connector ends from the old hoses. The you just use whatever fitting at the cooler end matches the outlets on the cooler .
And as you can see you fit it sideways. :) Think anything larger would need bumper surgery :D
Hope that helps
Darryl
1 - 5 of 5 Posts
