Guest
·Reading alot of threads about the standard Ecu,is it not possible at all to map it,even if some one were to lay there hands on a Mut11.
Or is that the Ecu is non programable ,but then with a mut settings can be reprogrammed.
So could some one actually define the reason why the standard ecu cannot be reprogrammed ?
just seems a little backward to be able to adjust code diagnostics and not tune from it.
Are the ecu's a sealed unit?
